jsbaker
Kenmore electric range\oven: I've gone too far to give up now!
4 posts in this topic
Brand: Kenmore
 Type: Range/Oven
Model: 911.9344190 Serial: 5A264454Q
Oven won't heat; rangetop works fine. If I turn the oven control knob to Bake (any temperature), Broil or Clean, the bottom, red ("Pre-heated") light blinks and neither element begins to heat; no error code appears in clock display. Both elements in oven are intact and will heat if I manually close the electromagnet relays on circuitboard.
I replaced the Clock/Control Board (Part #: WB27K5127). Unfortunately, the new part didn't correct my problem.
I thought that I might have reconnected the wires for P3(L1) and P4(N) backwards [P5(BROIL), and P6(BAKE)], but when I reversed them, it made no difference.
I have no Ohm/Multimeter to test the SENSOR (Part #: WB21X0158).
The the Clock/Control Board has been replaced and both elements are intact and functional. Could it be anything other than the sensor at this point (I'm trying to decide whether to buy a ohm/multimeter or just go ahead and buy the sensor). Are there other things I should check on the range/oven before buying either the ohm/multimeter or the sensor?
Please help me save what's left of my dignity (after buying and replacing the wrong part).
Lower Than a Grasshopper
Might as well just go buy a sensor and if that dosn't work wet your figers and stick em in the outlet to check for 220:yikes: But for future use get yourself a ohm/multimeter
Thanks, FatMan, for the quick reply!
Hope I don't have to check the outlet :shock:
Meters are cheap and easy to use. There's really no excuse not to have one.
