whirlpool m#wtw57esvwo
1 reply to this topic
#1 bmmc
bmmc
    Sōhei
  • Chief Appliantologist
  • 158 posts
Posted 16 May 2012 - 09:55 AM
this washer has no water level switch.the water pressure tube goes to a two position fabric softener switch.the washer will fill half full & begin to agitate then stop.then some times it will begin to fill again & overfill.the water valves are good & the plastic pressure tube is ok with no holes.there is a atc switch(which appears to be the fabric switch),a atc sensor,a flow meter,& load sense which appears to be part of the timer.where do i start?
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 16 May 2012 - 01:04 PM
Load Sense Switch (water level)
(known to be failure prone)
http://www.repaircli...R=154&N=1550760
Heat-Selector-Switch-W10292584-01266514.
