Sign in to follow this
Followers 0
bigboi407
Maytag Tub seal Kits 12001234 & 21001868
5 posts in this topic
hello again, i am looking through parts that were never inventoried when my dad had some fools running the warehouse, and i have kits numbered
12001234 And kit 21001868
id like to know which machines are compatible with both above kits, what i could find was the 12001234 fit the older peforma and the 21001868 fits maytag ensignia, im thinking that those kits fit more than just 1 machine per, or am i mistaken?, id like to know wether they only fit just 1 model number of machine or if the kits fit into multiple models or just the one i found? if they fit more than one id like to know what machines are compatible with each above kit
The manufacturer has replaced part number 21001868 with this item, part number 21002237
The manufacturer has replaced part number 12001234 with this item, part number 21002237
Part Number 21002237 replaces
35-3647
35-2972
35-2716,
35-2647
21001868
21001508
21001297
21001296
12001561
12001234
Maytag Atlantis belt drive Washers
so Both those kits fit ALL those above machines?? one looks much different than the other, but thats the correct number on the kits....
Where did you find that info, is it something i get access to if i buy a full apprenticeship?
I also have a ton of timers and i was reading that some replaced others so even though theres 2 part numbers they still do the same functions and can be used in the same machine...
The above list was compiled form different parts web sites ...
The "older" Seal Kits may look different because the "replacements" kits may be "new improved", and last longer,
and may include some parts not needed with all models.
The newer replacement Timers may have some included internal Contacts / Cams / circuits
that may might not be needed for all models, but are inside the replacement Timers ...
where do i cross refrence timers to see which two can be used in the same washer/dryer, an ebayer i buy stuff from can tell me if i give them a part number, what other timers can be used in the machines i need timers in, But will not tell me where their getting the information
Followers 0
