Block of ice
Sub Zero Ice maker
2 replies to this topic
#1 robpopper
robpopper
  • 1 posts
Posted 19 May 2012 - 04:27 PM
Unit is a Sub Zero model 532, in constant use for about 15 years. Problem is with the ice maker and started several months ago. Ice cubes seem to be properly made and drop into the tray. About 10 minutes later water enters the tray and of course freezes. The result is a single large block of ice with the individual cubed embedded within the block. Any thoughts on how to resolve this issue will be greatly appreciated. Thanks for looking.
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,467 posts
  • Flavorite Brew:Killians Red
Posted 19 May 2012 - 05:22 PM
So it seems the mold is overfilling? Chunk of ice is to large to be harvested?
not sure I understand yer problem...sounds like a valve leaking thru...
#3 jumptrout
jumptrout
  • 1,134 posts
  • Flavorite Brew:Coors Light
Posted 19 May 2012 - 05:25 PM
Your ice maker is either over-filling and excess water is going into the ice bin OR the ice maker has a crack in it and is leaking into the ice bin OR has become unlevel and leaking into the the ice bin.
You will have to determine which it is.
