LG LFC25776SW Leaking Water
LG Refrigerator Leak Leaking Water
5 replies to this topic
#1 georgemartin601
georgemartin601
    Yamabushi
  • 62 posts
Posted 20 May 2012 - 10:25 AM
New LG fridge as of last Wednesday. Woke up Friday and Saturday morning to puddles of water underneath and around it. There is no moisture near the water line on the floor (back of the fridge), none on the water line itself, none at the water line connection on the fridge, and none on the line from the connection going to the icemaker. At least it appears there is no moisture in these areas or on these parts. The only moisture I see is in the drip pan underneath a white plastic tube leading down from inside the unit. I'm assuming this is collecting/disposing of condensation or something. There is moisture however - in the form of a big puddle - underneath the fridge. Any thoughts? An authorized LG service tech is coming out in 4 days. Thanks
#2 RegUS_PatOff
  • 30,269 posts
Posted 20 May 2012 - 11:11 AM
may be from Freezer Defrost Drain Tube ... into Drip Pan # 319A (cracked ?)
#3 georgemartin601
georgemartin601
    Yamabushi
  • 62 posts
Posted 21 May 2012 - 09:10 AM
I disconnected the water line and turned the ice maker off yesterday morning. No puddle this morning. Not sure if it's worth noting. Is the defrost cycle still the same with water line disco'd? thank you.
#4 RegUS_PatOff
  • 30,269 posts
Posted 21 May 2012 - 11:31 AM
... Is the defrost cycle still the same with water line disco'd?
yes
#5 georgemartin601
georgemartin601
    Yamabushi
  • 62 posts
Posted 23 May 2012 - 02:12 PM
FYI - tech was out today. Replaced a leaking inlet valve. Thanks
  • 24,321 posts
Posted 24 May 2012 - 07:00 AM
Domo for the followup!
For future readers, here's the part link to the water inlet valve ==> http://www.repaircli...JB2010A/1345056
Also tagged with one or more of these keywords: LG, Refrigerator, Leak, Leaking Water
