Bottom mount fridge drain problems
5 replies to this topic
#1 MAYBERRY
MAYBERRY
  • Chief Appliantologist
  • 19 posts
  • Flavorite Brew:BUD LIGHT
Posted 21 May 2012 - 01:45 PM
GE Profile refrigerator M# PDS18SBMALBS .Having a reaccurring problem with the drain freezing up causing the fan to jam up in the ice.First time got customer to let box defrost with doors open for 2 days.I took it all apart and ran hot water and tubing down the drain.Water ran down drain quickly so i figured it to be repaired.About a month later" RECALL."Any suggestions?
#2 vee8power
vee8power
    Kohai
  • 441 posts
  • Flavorite Brew:Folgers
Posted 21 May 2012 - 06:07 PM
Those are pesky. I use a foil heater from Supco taped underneath the metal channel that sits below the evap fan. The SH221 is perfect.
    Shōgun
  • Master Samurai Tech
  • 30,203 posts
Posted 22 May 2012 - 07:21 AM
Good tip, Vee8!
Mayberry, here's the part link to the heater ==> http://www.repaircli...er/SH221/965750
#4 Rocket Appliance
Rocket Appliance
    Sōhei
  • Scholar of Appliantology
  • 136 posts
Posted Yesterday, 10:01 PM
Vee8....thanks for the tip, I've been battling this same problem...I've been back every Friday for a month now...at no charge of course to the customer. I love the foil heater idea! But I have one question..maybe a obvious answer but what would wire that heater to? I would assume it would go in line with the defrost heater? Or would it be on always? Thanks for your time
#5 vee8power
vee8power
    Kohai
  • 441 posts
Posted Today, 07:42 AM
Wire it in parallel with the defrost heater, before the defrost thermostat; it will be on for the whole 35 minutes of the defrost cycle that way. Make sure to melt all the ice and make sure the drain is clear.
#6 Rocket Appliance
Rocket Appliance
    Sōhei
  • 136 posts
Posted Today, 02:25 PM
Great thanks vee8 that should work well, and keep the water flowing 👍 really appreciate it 😊
