Need Substitute for Ball Check
8 replies to this topic
#1 milano maroon
milano maroon
  • 8 posts
  • Flavorite Brew:bud
Posted 21 May 2012 - 08:59 PM
I think I have narrowed down my dishwasher problem. My Maytag MDB9100AWB dishwasher doesn't seem to have very much pressure during the wash cycle. I removed the drain cover plate to inspect the drain impellor. There was supposed to be a check ball there which closes during the wash cycle. It is missing which I believe means lower wash pressures.
Anyway here's the problem. This part is discontinued. The replacement part is for the later series and is too small.
Does anyone know of a similar sized ball used in another machine? Looks like I need a 7/16" to 1/2" diameter ball.
I hate to scrap a good machine for what used to be a $4 part. I have attached a picture (1 inch square) of what I need.
Please let me know,
Jeff
#2 RegUS_PatOff
  • 30,216 posts
Posted 21 May 2012 - 09:30 PM
MDB9100AWB
series 10 or series 15
(serial number)
#3 milano maroon
milano maroon
  • 8 posts
Posted 21 May 2012 - 10:11 PM
My serial number is:
15039541YY
The hole in the drain cover plate where the check ball seats is about 3/8" in diameter. With the tapered seat area a little more. Doesn't that mean the ball needs to be at least that big so it doesn't go through?
#4 RegUS_PatOff
  • 30,216 posts
Posted 21 May 2012 - 10:20 PM
series 10 Check Ball
99001798
NLA
15039541YY
series 15 Check Ball
99002281
http://www.repaircli...rtDetail/786065
I don't know...
unless someone replaced the Drain Cover with the earlier version
#5 milano maroon
milano maroon
  • 8 posts
Posted 21 May 2012 - 10:55 PM
Thank you for your reply. I am totally confused. Maytag only lists one drain cover being available. Part number 99001795 which they say is for Series 10. They don't list one for series 15.
You are correct, I have a Series 15 which according to the Maytag parts list takes part number 99002281 - the small (less than 1/4" diameter) ball.
Here is a picture of my drain cover (with the ruler) which seems to match the ones you can see from the parts dealers websites. It just doesn't look like it will work.
I also attached a picture from the parts dealer's website for comparison. Looks the same as mine to me.
I know other dishwashers use similar check balls. I was hoping someone might have worked on one or had some parts laying around and could steer me to a make and model which would work.
Do you know of a substitute which is close to the same size?
#6 RegUS_PatOff
  • 30,216 posts
Posted 21 May 2012 - 11:11 PM
maybe someone else knows
#7 milano maroon
milano maroon
  • 8 posts
Posted 21 May 2012 - 11:19 PM
Again you're correct. That parts diagram and list show only one drain cover, which has a 3/8" diameter port, and one check ball, less than 1/4" diameter. What am I missing?
I am tempted to try this check ball for a Sears dishwasher. Looks close, what do you think?
#8 kdog
    RoughShod
  • 7,428 posts
Posted 22 May 2012 - 10:47 PM
http://www.repaircli...l/302709/480671
#9 milano maroon
milano maroon
  • 8 posts
Posted 23 May 2012 - 10:05 AM
Thank you.
