GE Profile Model Number TBX25PRBSRWW Water Leaking
2 replies to this topic
#1 cornucopia
cornucopia
  • 1 posts
Posted 22 May 2012 - 10:43 PM
The water is leaking from the control unit in the fresh food area. From what I have read, the defrost drain tube is clogged. Can anyone help me with how to access the drain tube. Thanks.
#2 kdog
    RoughShod
  • 7,466 posts
Posted 22 May 2012 - 11:03 PM
You need to remove the floor of the freezer
#3 Brooke Falconer
Brooke Falconer
    Ikkō-ikki
  • Appliantologist
  • 41 posts
  • Flavorite Brew:Heif
Posted 22 May 2012 - 11:10 PM
Drain tube should be access from the back of the fridge. Pull it out and remove all pieces and flush them out. Remove compressor kickplate (cardboard) and gently cut the zap strap to remove the entire drain tube. To reinstall use a silcone around drain tube opening and reinstall zap strap.
