Sub Zero 601F Ice buildup and moisture in ice bin
sub zero ice trough moisture
6 replies to this topic
#1 richards
richards
  • 3 posts
Posted 24 May 2012 - 09:04 PM
The metal bar that goes across the back of the freezer has a wall of ice on it. The ice in the basket tends to quickly turn into a block of ice (more so in the back of the drawer). What's causing this? How can it be resolved? I found info on the web that indicates a part that heats the trough should be added, but it appears to no longer be made.
Thank you in advance for you input.
-Richard
#2 RegUS_PatOff
  • 30,226 posts
Posted 24 May 2012 - 09:29 PM
pictures ?
  • 24,258 posts
Posted 25 May 2012 - 05:53 AM
Could be a defrost failure; could be a leaking ice maker. Need a visual. Post some photos like GMF Reg suggested.
#4 richards
richards
  • 3 posts
Posted 25 May 2012 - 08:59 PM
Here are the images. There is water fall shaped ice on the metal bar on the non-icemaker side and both above and below the icemaker.Posted Image
Posted ImagePosted Image
  • 24,258 posts
Posted 29 May 2012 - 07:21 AM
Looks like a frozen condensate drain. You'll need to remove the icemaker and the back inside wall to clear the ice from the trough and then clear the drain. You'll need to add a condensate drain heater kit or it'll happen again.
#6 richards
richards
  • 3 posts
Posted 29 May 2012 - 03:00 PM
Thank you. Do you happen to have a part number for the kit?
#7 woftam
woftam
    Ikkō-ikki
  • Master Appliantologist
  • 28 posts
  • Flavorite Brew:red wine
Posted 29 May 2012 - 05:59 PM
When you take ice maker and trough cover off there will be a bi-metal you need to check while it is cold. Not main defrost bi-metal. If lower bi-metal is closed trough and drain heaters will need replaced.
There is a huge difference between 10 years experience and one years experience ten times over.
