RCA washing machine ( VBXR1060V) doesn't agitate or spin
7 replies to this topic
#1 avdistribution
avdistribution
    Ikkō-ikki
  • 23 posts
Posted 30 May 2012 - 11:15 AM
Lid switch fires up motor but no agitation or spin.
Belt is in one piece but the clutch pulley doesn't turn freely (not sure if it should).
Is this most likely the belt, the clutch or worse?
#2 RegUS_PatOff
  • 30,689 posts
Posted 30 May 2012 - 02:12 PM
http://www.repaircli...PartDetail/1223
#3 avdistribution
avdistribution
    Ikkō-ikki
  • 23 posts
Posted 30 May 2012 - 02:33 PM
I took the belt off and it's badly frayed but not sure if that was caused by another problem or if it's the culprit. Anyway clutch moves freely in either direction now, but the trans pulley doesn't seem to.
#4 RegUS_PatOff
  • 30,689 posts
Posted 30 May 2012 - 02:43 PM
I'm not a Master on that type of Washer ..
maybe another user on here ...
#5 avdistribution
avdistribution
    Ikkō-ikki
  • 23 posts
Posted 30 May 2012 - 03:26 PM
Me neither. I had a Whirlpool that aside from a couple of pumps/couplers lasted without repair until it was mostly rust. I "inherited" this one and don't even know if the drum should turn freely when the belt is off. Thanks anyway!
#6 kdog
    RoughShod
  • 7,433 posts
Posted 01 June 2012 - 01:08 AM
:boohoo:
http://www.repaircli...38X10002/279566
Transmission-Assembly-WH38X10002-0058375
#7 avdistribution
avdistribution
    Ikkō-ikki
  • 23 posts
Posted 05 June 2012 - 07:01 PM
Is it possible there's something else preventing it from rotating or is it pretty much a sure thing it's cooked? Is it worth digging more to see if there's an obstruction or should I just bite the bullet and get a new washer?
#8 jb8103
jb8103
    Kohai
  • Chief Appliantologist
  • 459 posts
  • Flavorite Brew:Ginger ale
Posted 06 June 2012 - 04:39 AM
Just for knowledge I'd strip that thing down to the last screw. Likely you'll be calling the local scrap guys after, but I've done this a couple times and it's worth doing.
First, do no harm.
