Sign in to follow this
Followers 0
gdematteo
Maytag Neptune Washer Model mah5500bww
6 posts in this topic
Working fine and then half way through a cycle it started buzzing and wouldn't finish the cycle. Then it wouldn't restart until I unplugged/plugged it back in. It will sometimes run now doing that but there is often a buzzing noise coming from the back near where the hoses connect in the upper corner. There is no error code.
Thanks!
it could be the Cold Water Valve not working / clogged ..
What water temperature Wash Cycle do you use ? warm ?
Maybe only Hot is entering..
Try starting a cold Wash cycle.
Thanks for the suggestion. I only run cold though.
Yeah that seems to be what was buzzing when I tore it apart earlier. You think I should just swap that out?
OR check its input filter / screen
Followers 0
