Bosch Dryer with a Loud Buzzing Noise WTMC3321US/03
Bosch dryer noise
6 replies to this topic
#1 Samurai Appliance Repair Man
  • 24,199 posts
Posted 02 June 2012 - 06:48 AM
Went out on a Bosch dryer that makes a weird, loud buzzing noise. Check it out..
I disassembled the dryer and found one of drum rollers was stiff and make the characteristic chattering noise when you spin it by hand. That's an obvious problem that has to be fixed. But I've never heard a bad roller make that kind of noise before and I'm wondering if there's something else going on like a bad drum bearing. I want to make sure I have all the parts I need when I go back and fix this dryer. Anyone ever run into this before?
#2 RegUS_PatOff
  • 30,188 posts
Posted 02 June 2012 - 09:25 AM
almost sounds like the Motor bearing noise ..
try it without the Belt
#3 RegUS_PatOff
  • 30,188 posts
Posted 02 June 2012 - 10:01 AM
if the Motor is OK, then, while the Belt is still off, spin the Drum by hand.
Any noise / vibration ?
  • 24,199 posts
Posted 02 June 2012 - 10:33 AM
Good thought on the motor bearing. The drum spins smoothly by hand so the drum bearing seems good.
I was talking with Jerry (appl.tech.29501) via Voxxer and he ran into the same thing with a Bosch Axxis dryer (different but similar). After replacing the motor and drum rollers, the noise remained. Problem turned out to be the blower wheel! When I go back, I'll take the drum rollers and a blower wheel with me. When I get this one fixed, it'll be a good one for the Appliantology knowledge base.
#5 Budget Appliance Repair
  • 3,994 posts
Posted 03 June 2012 - 06:21 AM
Sounds to me more like the blower wheel rubbing on something. Maybe a foreign object sucked down into lint duct area and blower wheel.
William Burk (Willie)
Eureka, CA 95501
#6 RegUS_PatOff
  • 30,188 posts
Posted 03 June 2012 - 06:29 AM
yes, more like a Blower noise than a Motor Bearing ..
  • 24,199 posts
Posted 10 June 2012 - 04:35 PM
Just wanted to post the outcome on this one.
Finding the source of this noise in this Bosch dryer was tricky. Judging by the sound, the noise had to originate from either the motor or the blower wheel. The problem turned out to be the blower wheel. The noise was only heard in a heated dryer cycle. Apparently the heated air would deform the plastic blower wheel just enough to make it contact the blower housing while rotating.
Part link to the blower wheel ==> http://www.repaircli.../491640/1107382
