Kenmore refrigerator #365.9530713, FF light off
6 replies to this topic
#1 DanInKansas
DanInKansas
    Senpai
  • PipPipPipPip
  • 578 posts
  • Flavorite Brew:Lion Imperial or Shiner Bock
Posted 02 June 2012 - 09:06 PM
Okay, so this is embarrassing and confusing, because it's my personal fridge.
Light in the fresh food compartment was flickering on and off for a while. Finally it gave up. Took the bulb out and inspected it, bulb is fine.
Replaced the switch at the bottom of the compartment, thinking I had a sticky switch. Verified the switch's operation before installing it.
Replacing the switch made no difference -- still no light.
Took out the bulb again, and put my meter on the light socket -- I got a reading of 22 volts. Didn't believe the reading, so I did it again. Once again, got 22 volts.
I can understand how I would get 122 volts. I can understand zero. I can not understand 22.
Anyone got an idea?
What is the simplest, dumbest explanation? Because that's the most probable one.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 02 June 2012 - 10:23 PM
365.9530713
can you check that model number again ?
#3 DanInKansas
DanInKansas
    Senpai
  • PipPipPipPip
  • 578 posts
Posted 02 June 2012 - 10:26 PM
Sorry, misread the model tag. That should be
363.9530713
#4 RegUS_PatOff
  • 33,588 posts
Posted 02 June 2012 - 10:38 PM
... I can understand how I would get 122 volts. I can understand zero. I can not understand 22.
not electronically controlled ...
just the wiring and the Switch and Light Socket ..
must be a bad connection somewhere
    Shōgun
  • Master Samurai Tech
  • 30,624 posts
Posted 03 June 2012 - 07:44 AM
22 volts is in the range of junk voltage and is almost always associated with a corroded connection, floating neutral, etc. Check resistance of the neutral side of the socket to the neutral spade on the refrigerator plug. If you get a high resistance reading (anything above 2 ohms) then use the wiring diagram to narrow down the hunt and find the high resistance point. Do the same technique on the L1 side of the socket.
#6 DanInKansas
DanInKansas
    Senpai
  • PipPipPipPip
  • 578 posts
Posted 04 June 2012 - 08:02 PM
I haven't heard the term "junk voltage" before. So a corroded connection will begin to act like a load in series and allocate voltage to itself?
    Shōgun
  • 30,624 posts
Posted 04 June 2012 - 10:20 PM
Ezzacly. They can also generate heat, sometimes lots of heat, enough to fry a contact or a terminal connection. A loose connection will act the same way.
