Bosch dishwasher jet dry rinse not dispensing
#1
Posted 04 June 2012 - 12:27 PM
I've tried cleaning the area around and inside the rinse dispenser cover, to no effect.
I believe I have to remove the stainless steel outer door shell to get at the back of the dispenser inside the door to remove the electrical connectors and release the unit.
At that point I'm hoping I can clean it with a mixture of vinegar/water and put it back in. That seem reasonable?
What I'm not sure of is how to remove the outer door cover. There are about 10 or 12 torx screws on the inside perimeter of the door - do I remove all of those to take the outer SS shell off, or ? Any issues to watch out for when removing/replacing the SS shell, or the dispenser unit itself?
I've looked for a repair manual but haven't found one yet, of anyone has any info I'd really appreciate it...
#2
Posted 04 June 2012 - 01:34 PM
Bosch SHX46A05UC...
To unleash the real power of the Academy,
become an Apprentice to get repair manuals and lots of other goodies.
SHX46A05UC / 14
Dispenser
http://www.repaircli...tDetail/1055122
#3
Posted 04 June 2012 - 01:44 PM
#4
Posted 04 June 2012 - 01:57 PM
Not sure what other numbers are needed to determine the dispenser. The model number I gave is the entire model number I have on the documentation.
We have an orange sticker that either came off the dishwasher or the paperwork that came with it...it has:
Model number as already noted
SO#
Serial #
Another number that starts w/"TS"
Which of those is required to determine the exact dispenser? Pics of the dispenser below.
And: Are you implying that there is no fix for this issue and I'm going to need to replace the dispenser?
#5
Posted 04 June 2012 - 02:03 PM
The Dispenser could be tested..
some electrical tests would need to be done..
#6
Posted 04 June 2012 - 02:41 PM
Full SN from the sticker on the dishwasher is: SHX46A05UC / 14. Below that is another number: FD8303 01458. Hopefully that helps identify the correct dispenser. <EDIT> Thanks for confirming the part above.</EDIT>
I went through the document you provided the link to (thanks) and it appears to remove to remove the front panel I have to remove the lower six torx screws (three on each side) on the inside of the door and slide the panel down...the four torx screws at the top on the inside appear to secure the control panel. That sound right?
And to confirm - you're saying the existing unit is likely a goner and must be replaced? I did find a statement in the manual in troubleshooting on the rinse dispenser having issues that refers to replacing an actuator: I've also seen posts in some other searches talking about cleaning, but nothing appears clogged on the rinse dispenser part of the assembly that I can see.
Detergent or rinse
aid won't dispense
properly. Dispenser actuator (A2) failed. Turn off dishwasher and replace actuator.
Thanks for the assistance.
Edited by Danabw, 04 June 2012 - 02:56 PM.
#7
Posted 04 June 2012 - 02:55 PM
1) edited previous part number link... dishwasher is: SHX46A05UC / 14. .
... appears to remove to remove the front panel I have to remove the lower six torx screws
... you're saying the existing unit is likely a goner and must be replaced?
2) sorry, I'm not a Bosch Master, maybe someone else on here is ..
3) could be, if the Actuators and Levers are in place.. could also be a bad Controller
some electrical tests may need to be done
#8
Posted 04 June 2012 - 04:57 PM
OK, Bosch masters, chime in!
#9
Posted 04 June 2012 - 05:57 PM
does the detergent cup open in the cycle properly? If so, Prolly a broken linkage internal to the dispenser...same actuator for both...
#10
Posted 04 June 2012 - 06:35 PM
Yes, remove the lower 6 or 8 screws from the inner door to remove panel...
Great, thanks!
Yes, the detergent part works fine, just the rinse doesn't release. I'll have to see if I can order an actuator then.
Do you happen to know the part number or name that will lead me to it...I'm looking here, on this page:
http://www.repaircli...hx46a05uc-==c33
This one?
http://www.repaircli...r/166632/935392
Dispenser Actuator
Item # 935392
Yes?
Edited by Danabw, 04 June 2012 - 06:53 PM.
#11
Posted 04 June 2012 - 07:51 PM
I have always just replaced the dispenser assembly.
for sure pull the panel off and have look...
#12
Posted 04 June 2012 - 10:23 PM
Me, too. It's a sure-fire repair for this problem, no call-backs!
- KurtiusInterupptus likes this
#13
Posted 04 June 2012 - 11:42 PM
Thanks very much for the help/advice!
