MAYTAG BRAVO WASHER MVWB300WQ1
Bravo MVWB300WQ1 bangs
2 replies to this topic
#1 Gatsumi
Gatsumi
  • Chief Appliantologist
  • 11 posts
Posted 04 June 2012 - 04:46 PM
Washer goes off balance and bangs. MVWB300WQ1. Changed strutt assy. worked once then off balance and bangs. Any thoughts, Is there counter weights or water or anything secret in the inner tub?
#2 NCARepair
NCARepair
    Sōhei
  • 216 posts
Posted 05 June 2012 - 06:56 PM
Tub has water balance rings built in to it. Does this do this with an empty basket? If it does you may need to replace the basket. Had this problem and reluctently changed the basket and it fixrd it. This machine has fisher & paykel all over it. At least they tell you how to determine if the basket is bad.
#3 nickfixit
nickfixit
  • 1,990 posts
  • Flavorite Brew:Glen Livit
Posted 10 June 2012 - 09:36 PM
It could be caused by the main shaft being rusted. The basket needs to rise and fall to wash and spin. If it hangs up when it needs to drop into spin position it will go off balance and give UL errors. Pull the basket and inspect the shaft.
Also tagged with one or more of these keywords: Bravo, MVWB300WQ1, bangs
