Whirlpool WTW7340 - HC code
2 replies to this topic
#1 Golferdude
Golferdude
    Ikkō-ikki
  • 21 posts
Posted 04 June 2012 - 07:46 PM
I have had this washer for about a year and a half. All of the sudden it is giving me a "HC" code after each wash. I know it means the cold and hot water lines are reversed. But I haven't switched anything and the lines are hooked up correct. I assume there is a sensor somewhere? Any ideas or suggestions?
Thanks...
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 04 June 2012 - 08:21 PM
Tech Sheet - W10310047.pdf
link PM'd
Thermistor built into the Water Valve Assembly
http://www.repaircli...tDetail/1862767
Water-Inlet-Valve-W10364988--01092745.jp
#3 Golferdude
Golferdude
    Ikkō-ikki
  • 21 posts
Posted 26 July 2012 - 01:52 PM
link PM'd
Thanks...sorry I didn't reply sooner...my computer crashed and finally got it all back up and running... Unbelieveable on all of the electronics on the valve...hopefully it won't go out as fast the second time... Will read over the info you sent me and see if I can test it...
