lg wm0532hw error code le
lg wm0532hw washer
2 replies to this topic
#1 Timmothy J Lee
Timmothy J Lee
  • 1 posts
Posted 06 June 2012 - 01:09 PM
I would like to find service manual for this washer if possible. My wm0532hw washer errors out with le or pf. Many times when this happens I restart the machine and bang on top of the machine in few different places when load suppose to turn. This fixes the problem so i feel it has wire connection issue somewhere. I replaced the ball sensor and it worked for awhile but the problem returned. I'm having to hit top of machine once again. Anyone out there know where I can get a copy of service manual or repair suggestions. Thanks
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 06 June 2012 - 01:47 PM
PF • The washer experienced a power failure.
LE • The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to
the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS
and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The hall sensor is out of order/defective.
LG WM0532 Service Manual
http://appliantology...dded-lg-washer/
    Shōgun
  • Master Samurai Tech
  • 30,392 posts
Posted 06 June 2012 - 02:44 PM
Some background info on diagnosing the le error code ==> http://fixitnow.com/...ses-and-repair/
Part link to the hall sensor ==> http://www.repaircli...&PartID=1268238
