Fisher Paykel IWL 16 Drip in Tub
1 reply to this topic
#1 jss_old
jss_old
    Ikkō-ikki
  • 25 posts
Posted 07 June 2012 - 04:50 PM
Hi.I recently had a code 37 fault with water on the floor under the machine and then the washer died. I replaced the drain pump and control board (added in the fuse) and back in business. Now I get a drip inside the tub when the machine is done with the cycle and the water is on at the shutoff. Turn the shutoff off and the water stops. Ideas? Is there a way to test the water inlet valve? As always, thx much for your help!!
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,917 posts
  • Flavorite Brew:Killians Red
Posted 07 June 2012 - 04:59 PM
You already did...figure out which valve is leaking thru (prolly cold) and replace it.
