ND error
Samsung wf206bnw/xaa
12 replies to this topic
#1 mtbikemom
mtbikemom
  • 9 posts
Posted 07 June 2012 - 04:56 PM
I am getting a ND error on my front load washing machine. I replaced the drain pump today and made sure the hoses were clear and still I got the error. What else could be causing the machine to give this error? Thanks in advance!
#2 Scottthewolf
Scottthewolf
    Senpai
  • 2,953 posts
Posted 07 June 2012 - 05:42 PM
Oh, you're in trouble now! You forgot to tell us the brand of your washer and the model number, the Samurai is going to sic his German Shepherd on you!
Scott Wolf
#3 mtbikemom
mtbikemom
  • 9 posts
Posted 07 June 2012 - 08:02 PM
Samsung wf206bnw/xaa. Sorry was so irritated looks like I forgot to include that.
#4 NCARepair
NCARepair
    Kohai
  • Appliantologist
  • 333 posts
Posted 07 June 2012 - 08:42 PM
Is the machine draining? Or is it draining and still giving the code?
#5 mtbikemom
mtbikemom
  • 9 posts
Posted 07 June 2012 - 09:01 PM
It wasn't draining when I replaced the pump. After replacing the pump I ran a rinse/spin cycle and it drained most of the water before the nd error happened again. I tried to run a spin cycle after getting the error but it would not even spin. The door locked and then nothing happened for a few minutes until the error popped.
    Shōgun
  • Master Samurai Tech
  • 30,534 posts
Posted 08 June 2012 - 08:05 AM
Take the drain hose off the pump and blow into it to make sure it's free of gookus and debris.
#7 mtbikemom
mtbikemom
  • 9 posts
Posted 08 June 2012 - 08:31 AM
I took the drain hose off the washer and outside. I washed everything out of it with a water hose so I know the hose is clear. I checked the hose from the tub to the pump as well and didn't find any blockage there either.
#8 NCARepair
NCARepair
    Kohai
  • Appliantologist
  • 333 posts
Posted 08 June 2012 - 09:19 AM
Possible water level switch thinks there is still water in tub? Make sure water level hose is not blocked. Disconnect and blow through it to make sure.
#9 mtbikemom
mtbikemom
  • 9 posts
Posted 08 June 2012 - 09:31 AM
This is probably a stupid question, but which hose is the water level hose?
#10 mtbikemom
mtbikemom
  • 9 posts
Posted 08 June 2012 - 12:27 PM
Found the hose and blew it out. Trying to run a rinse/spin to see if it helps.
#11 mtbikemom
mtbikemom
  • 9 posts
Posted 08 June 2012 - 12:43 PM
It rinsed and drain some but then stopped and threw the nd error again. I have a tech out and he can't figure it out either.
#12 mtbikemom
mtbikemom
  • 9 posts
Posted 08 June 2012 - 01:42 PM
Could a bad drain/ water sensor be causing the problem? I really would like to try and fix this today. Laundry from three boys piles up quickly!
#13 mtbikemom
mtbikemom
  • 9 posts
Posted 09 June 2012 - 08:59 AM
I ordered the drain/water level or mems pcb. Going to try replacing that next. The washer will rinse and partially drain in the rinse/spin cycle, but quits doing anything at 11 minutes and throws th nd error. I am thinking one of the pcbs have gone bad. The repairman I had out yesterday had no clue what was wrong. Anyone have an opinion on whether or not I am headed in the right direction?
