Food grade high temperature tubing for hot water dispenser
5 replies to this topic
#1 hdheetderks
hdheetderks
  • Chief Appliantologist
  • 10 posts
  • Flavorite Brew:Any decent gin
Posted 13 August 2011 - 08:26 PM
The plastic tube between the 190 degree hot water tank and the spigot from which the water is dispensed has developed a leak.
The current tubing measures .300 inches ID and the metal outlet pipe it attaches to measures .420 OD.
The tubing should be rated for high temperature (the current tube has 275 degrees maximum printed on it), and it
obviously should be beverage grade.
Any suggestions what material specification to use for this and where to get some?
Henry Heetderks
#2 kdog
    RoughShod
  • 7,428 posts
Posted 14 August 2011 - 12:04 AM
Maybe :
http://www.repaircli.../8204511/909652
Generically Speaking, of course
#3 RegUS_PatOff
  • 30,276 posts
Posted 14 August 2011 - 12:17 AM
8178176.pdf :whistling:
#4 kdog
    RoughShod
  • 7,428 posts
Posted 14 August 2011 - 12:19 AM
You D'man reg !
#5 hdheetderks
hdheetderks
  • 10 posts
Posted 08 June 2012 - 09:28 PM
A few months ago I asked if anyone knew where to get food grade high temperature tubing to replace the leaking tube on the hot water dispenser on my sink. No answers. Anyway, here is a source; http://www.mcmaster....-tubing/=hw8sjz
This is good stuff; they have both non-reenforced and a reenforced versions. Not cheap, but it seems to be better than what came with the unit.
#6 kdog
    RoughShod
  • 7,428 posts
Posted 09 June 2012 - 02:15 AM
No answers.
I count 2 answers (possibly incorrect ones) - topics merged
