The days of Monkey Boy Service Calls are over...
Click here to check out our fun short course and learn how to get the most out of Appliantology.
kmerenda
Need to replace/repair water dispenser line
3 posts in this topic
The plastic tubing that connects the water dispenser to the water valve has been chewed through by rodents, close to where the tube connects to the valve. The tube is completely severed, and I'm not sure how to proceed with the repair, now that we have the rodent infestation taken care of. I'm also not sure which part I need for the tube. I'd appreciate any guidance. The fridge model is marked "GE TFX25JR, TFX22JR"
What is the model number???....found ON the unit..........ya got either a 25 CF or a 22 CF, can't have both.................Replacement water lines are two different part numbers....................WR17x3670 or WR17x3669.....checkrepairclinic for pictures, is this the part????
Thanks for the reply. Upon further inspection, I found that the damaged tupe is the tube coming from the water resevior assembly and going to the water valve. The other tube from the resevior that attaches to the door was also damaged, so I'm just going to replace the entire resevior assembly. The part I purchased is WR17X4358
