Frigedaire Gallery Front Loader won't run, door lock light on.
#1
Posted 10 June 2012 - 10:09 AM
History, I replaced the inner tub basket 6 months ago due to a broken spindle. 3 months ago, had a clog and had to clean out the drain, but have run at least 20 loads since then, probably 75 loads since replacing the basket.
Any help would be appreciated, I thought about replacing the door lock assembly, however that wouldn't explain tripping the breaker would it? Have checked the wiring to see if somehow a wire was pinched and burned out, but don't see anything. I'm not great with electrical wiring, so not sure what the next step is...
Thanks for any and all help!
#2
Posted 10 June 2012 - 11:47 AM
#4
Posted 10 June 2012 - 01:10 PM
At that time, did it fill with water before it tripped the Breaker ?.... After that it tripped the breaker anytime you tried to turn it on.
Does it fill with water now OK ?
If no other Lights come ON (Wash, Rinse, Spin)
then yes, the Door Lock Assembly is probably bad now, due to the constant Breaker overloads..
If it was tripping the Breaker just prior to the Spin Cycle, it could be a bad Drain Pump.
You may be able to test the Pump with an OHM meter, (should be about 15 OHMs)
OR disconnect the Pump, but the Door Lock still has a problem
which may be by-passed for testing.
#5
Posted 10 June 2012 - 01:15 PM
When you turn on the door lock light will turn on, and you can hear a slight hum, but that is it...
#6
Posted 10 June 2012 - 01:45 PM
#7
Posted 10 June 2012 - 02:18 PM
#8
Posted 10 June 2012 - 02:31 PM
depends where the hum is coming from.. Timer Motor (normal), Water Valve, Washer Motor ?... you can hear a slight hum
that may be close enough, could test with 120v... pump motor and it is reading 12.8 Ohms. The schematic says 15 +- 1 ohm. Replace?
#9
Posted 10 June 2012 - 02:49 PM
No hum, w/door lock switch removed, how would I test 120v? Have to install new door lock switch first?
#10
Posted 10 June 2012 - 03:19 PM
1) only if the Door Switch wires were somehow shorting to the frame.... Is it possible the switch was causing the breaker to trip
... how would I test 120v?
... Have to install new door lock switch first?
2) if you could apply 120v AC to the Pump Motor terminals ...
3) for testing, you could disconnect the Door Lock and connect the wires together (with electrical tape)
#11
Posted 10 June 2012 - 04:13 PM
Door lock switch ==> http://www.repaircli...ber=GLTF1670AS0
Drain pump ==> http://www.repaircli...ber=GLTF1670AS0
#12
Posted 10 June 2012 - 10:00 PM
Also tagged with one or more of these keywords: Frigedaire, Washer, Wont Cycle
