Frigidaire Gallery Series will not spin
Frigidaire Washer spinning
8 replies to this topic
#1 jcarter76
jcarter76
  • 5 posts
  • Flavorite Brew:Shocktop
Posted 10 June 2012 - 10:09 PM
My Frigidaire Gallery Series (Model# GLTF2940ES0) will no longer spin. I thought maybe it was a heavy load issue but I took 90% of the stuff out and it still will not spin. It sounds like it will drain but it just stops in the middle. I tried to start a new cycle but I get "do" on the screen and all the lights blink.
I've searched the boards and can't seem to find anything about this. Any help would be helpful. Thank you!
#2 RegUS_PatOff
  • 30,262 posts
Posted 10 June 2012 - 10:12 PM
... I get "do" on the screen
do = Door open
may be a bad Door Lock Assembly
http://www.repaircli...tDetail/1531974
#3 kdog
    RoughShod
  • 7,428 posts
Posted 10 June 2012 - 10:13 PM
Sounds like it thinks the door is open, see if dragging out one of those "heavy loads" has caused the door hook to get broken
http://www.repaircli...ber=GLTF2940ES0
#4 jcarter76
jcarter76
  • 5 posts
Posted 10 June 2012 - 10:17 PM
D'oh! That was dumb.
OK, just tried to run the rinse/drain cycle. It makes a noise as if it's going to go through with it but then just sits there. No spinning, draining, nothing. Just counts the timer down.
#5 kdog
    RoughShod
  • 7,428 posts
Posted 10 June 2012 - 10:24 PM
Sounds like time for Ye Olde Crap Trap Enema
#6 jcarter76
jcarter76
  • 5 posts
Posted 10 June 2012 - 10:27 PM
Outstanding. Looks like fun. :-/
I'll give that a try. Thanks!
#7 jcarter76
jcarter76
  • 5 posts
Posted 21 June 2012 - 12:22 AM
Finally got a chance to clean out the pump. Still having the same issue. What else can I do?
#8 RegUS_PatOff
  • 30,262 posts
Posted 21 June 2012 - 02:35 AM
after a few minutes in the "Spin" Cycle..
Check to see if the Door is locked.
Is it really locked ? (OR bad Door Strike)
If locked, then un-plug the Power Cord from the Wall Outlet.
Can you then open the Door right away ? (bad Door Lock Assembly)
OR only after a few minutes ? (good)
#9 jcarter76
jcarter76
  • 5 posts
Posted 08 July 2012 - 05:38 PM
The door is locked. I can open it right away when I unplug it.
Also tagged with one or more of these keywords: Frigidaire, Washer, spinning
