Dishwasher not draining at end of cycle
GE Profile gsd5130d02ww
4 replies to this topic
#1 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
  • Flavorite Brew:Beamish
Posted 10 June 2012 - 10:26 PM
Anyone know what's going on in the following:
The impellers are in good shape, no hose obstructions. When the unit is placed in diagnostic mode it goes through all the steps as it should including the last step being draining. But it will not drain in normal wash mode when it's finished. To get the water out at the end of the cycle it has to be restarted and then cancelled, then it drains.
Test
#2 kdog
    RoughShod
  • 7,428 posts
Posted 10 June 2012 - 10:36 PM
DD10-00.pdf
#3 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 691 posts
Posted 10 June 2012 - 10:53 PM
If all the functions work in diagnostic mode then you must have a bad timer/sequence switch.  There is also a main control board and I might be wrong but I believe the diagnostics test will bypass the timer/sequence switch. Maybe someone else can verify that
http://www.repaircli...9742&locID=2758
#4 RegUS_PatOff
  • 30,203 posts
Posted 11 June 2012 - 05:33 AM
http://www.repaircli...rtDetail/876974
#5 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
Posted 04 January 2013 - 11:25 PM
DD10-00.pdf
Turned out to need the kit mentioned in this pdf. Which included the sequencing switch. The sequencing switch alone didn't fix it, but was part of the fix.
Edited by Samurai Appliance Repair Man, 05 January 2013 - 07:16 PM.
Added part link to needed repair kit.
Test
