UV dye dryer vs UV dye injection
4 replies to this topic
#1 Tronicsmasta
Tronicsmasta
    Senpai
  • PipPipPipPip
  • 520 posts
Posted 15 June 2012 - 01:13 PM
I wanted some thoughts on using the dye dyer vs using uv dye injection method for leak detection... Thanks
Q
It is never a bad thing to leave it to the professionals. Inexperience can lead to more damage or risk of injury. You can always call A&E Factory Service (1-800-905-9505), Sears(1-800-469-4663), or local service man you can trust (servicemagic.com).
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,959 posts
  • Flavorite Brew:Killians Red
Posted 15 June 2012 - 02:53 PM
The only advantage I see to injection that you know that the dye is dispersed for sure...
I've had several instances where I installed a dye drier on a system known to have leak, came back a few days later, blacklite and goggles in hand, and found nothing. A quick press of the schrader valve reveals that the pellet/capsule has failed to rupture as designed...
otherwise, not much difference in the two. I find it difficult, in some well lit kitchens (natural light) to get it dark enough to see the uv and have to cover myself and the area in question with a heavy drop cloth to get a good read.
#3 certified tech group 51
  • 2,712 posts
Posted 16 June 2012 - 10:34 AM
I have not used the stuff in ether form myself......................Will it find a leak in the low side??????...........If it takes over a year or more for the refrigerant to leak out, does the dye leak out in a measurable amount?????
#4 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,959 posts
Posted 16 June 2012 - 01:58 PM
The claim I have heard is it will reveal leaks as small as a 1/2 oz. A year...
works well for me ...when it ruptures :-)
#5 Tronicsmasta
Tronicsmasta
    Senpai
  • PipPipPipPip
  • 520 posts
Posted 17 June 2012 - 12:50 AM
Yes it will find a leak on the low side because when the compressor cycles off, the refrigerant on the high and low sides equilize. I have a picture of a leak from the suction tube on the evap. the leak is between the cap tube and suction line. ill try to post it from my phone. I put the yellow glasses over the lens of mu phone and shined the uv light as i took the picture.
thanks for the replies.. at sears we only use the dye dryers by whirlpool and i kinda wish we used the injection as it would help see the leak faster maybe even the same day...
