#1
Posted 17 June 2012 - 03:34 PM
-Do you know where I can find this part
or
-if there is a similar part made for another model fridge that will also work?
-What do I do if I can not find a cover for these coils?
-Can I fashion one out of, say, tin foil and use that instead?
Your help is greatly appreciated. The freezer is starting to not keep things frozen - maybe because there is so much ice built up on the coils now.
Thank you.
Heating Up in NM
#2
Posted 17 June 2012 - 04:02 PM
Lower Coil Cover
http://www.repaircli...rtDetail/665694
BUT, chances are, the reason the cover was removed, you may need a new ADC Defrost Controller
(common fail)
http://www.repaircli...rtDetail/948430
Any part ordered from RepairClinic, can be returned for a refund (less shipping)
