Samsung Refrigerator - Moisture in Vegetable Crisper and under drawers
Moisture Drawers
6 replies to this topic
#1 HisRocker
HisRocker
  • 3 posts
  • Flavorite Brew:Sam Adams
Posted 18 June 2012 - 11:39 AM
Hi, the Samsung Refrigerator (French door / bottom freezer) is newer (2+ years old) -- there is moisture in the Vegetable crisper drawer and under the drawer (in the refrigerator).
Reading through online forums -- the number one reason appears to be a blocked defrost drain. I have checked the defrost drain and verified it is clear (poured warm water through it).
Key Question: Is there another reason, or reasons (things to check) which would cause moisture in the refrigerator (under drawer) when the defrost drain is clear?
Thanks, HisRocker
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 18 June 2012 - 11:42 AM
may be a bad Door Gasket
Try the George Wa$hington test on all (3) Door Gaskets ...
close the Door on George and slide him around the Gasket.
check to be sure he stays snug
    Shōgun
  • Master Samurai Tech
  • 30,032 posts
Posted 18 June 2012 - 12:03 PM
Please post your model number.
#4 HisRocker
HisRocker
  • 3 posts
Posted 21 June 2012 - 02:02 PM
Bottom Freezer / French door Refrigerator
Model: RF217ACPN
Compressor MK162D-L1U
#5 reelynyceguy
reelynyceguy
    Yamabushi
  • Appliantologist
  • 85 posts
  • Flavorite Brew:Good coffee
Posted 22 June 2012 - 06:39 PM
Stupid question: which defrost drain did you check, the fresh food or freezer?
Edited by reelynyceguy, 22 June 2012 - 06:39 PM.
"What can be asserted without evidence can also be dismissed without evidence." Christopher Hitchens
#6 Brooke Falconer
Brooke Falconer
    Ikkō-ikki
  • Appliantologist
  • 41 posts
  • Flavorite Brew:Heif
Posted 24 June 2012 - 11:25 PM
I have had an issue with a few of these fridges where the water continually drips into the bottom of the fridge and the crisper. According to Samsung, they want you to replace the rear fridge panel, although I found that didn't help much and it started to happen again. I jimmied the drain tray to make sure it had a high lip against the fridge panel, made sure the Styrofoam on the rear panel was completely dry before reinstalling and made sure the fridge was level if not a bit higher in the front to avoid this. I did this for three fridges and didn't hear back, but honestly, it seemed mickey mouse to me too! :whistling:
#7 HisRocker
HisRocker
  • 3 posts
Posted 25 June 2012 - 09:53 AM
reelynyceguy - thanks - Initially, I did check for a drain in the refrigerator, but couldn't find one. Next, I checked the freezer defrost drain -- Yours is a very good question because -- based on Brooke's comments -- I didn't see a drain for the refrigerator after taking out the two crisper drawers -- I take it is towards the back of the refrigerator unit?
Brooke - thanks for your very good comments too... I'll check the level on the refrigerator and make sure it's slightly higher in the front ... will look for the defrost drain in refrigerator again --
Can you or reelynyceguy specify exactly where this drain is located -- based on your comment above -- I would think it's on the back bottom (center?).
Thanks again, HisRocker
