Frigidaire 3cu ft Front Load Washer (Good Series)
Will not spin
4 replies to this topic
#1 tstandridge
tstandridge
  • 11 posts
Posted 18 June 2012 - 01:49 PM
I have looked at the other topics on this site to check my washer. I did not find any debris in the drain hose assemblies or in the pump. The pump will drain water in the Rinse and Spin Cycle and Spin and Drain cycle, but the tub will not spin. I can put the washer in test mode and it will drain and spin at high speed. Any ideas on what parts to check next?
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 18 June 2012 - 02:03 PM
... The pump will drain water in the Rinse and Spin Cycle and Spin and Drain cycle, but the tub will not spin.
... I can put the washer in test mode and it will drain and spin at high speed.
model number ?
bad Door Lock Assembly
OR
the plastic Door Strike
    Shōgun
  • Master Samurai Tech
  • 30,209 posts
Posted 18 June 2012 - 02:05 PM
Model number help here ==> http://www.repaircli...My-Model-Number
Usually a bad door latch assembly, here's the part link ==> http://www.repaircli...1763202/1531974
#4 tstandridge
tstandridge
  • 11 posts
Posted 18 June 2012 - 02:08 PM
Model # is LTF2140ES0
#5 tstandridge
tstandridge
  • 11 posts
Posted 21 June 2012 - 08:22 PM
I received my parts today and had our washer fixed in 5 minutes. You guys are AWESOME!
