kenmore headscratcher
model----11069422801
7 replies to this topic
#1 kevinmac6591
kevinmac6591
    Ikkō-ikki
  • 20 posts
  • Flavorite Brew:lone star
Posted 18 June 2012 - 05:49 PM
kenmore dryer model 11069422801 runs but no heat voltage at wall 120 and 120 and 240 across voltage coming out of terminal block red to neutral 120 black to neutral 120 red to black 240. operating stat(on blower) has continuity heating element-continuity high limit (bottom of element )-continuity high limit top of element can-continuity. homeowner has replaced timer with new one checked and is correct timer and is hooked up correctly(kinda hard to mess up this one has plastic molded plugs with wires installed only plugs in one way) whats next? could i have the mythical defective motor switch if so gotta buy the whole motor on this one. any help appreciated . thanks in advance.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 18 June 2012 - 06:13 PM
run the Dryer in a no-heat Air-Fluff Cycle.
Measure for 120v AC from each terminal of each the Thermal Devices to chassis (ground)
and at each end of the Heating Element.
    Shōgun
  • Master Samurai Tech
  • 30,703 posts
Posted 18 June 2012 - 07:21 PM
Testing the heating element:
http://www.youtube.com/watch?v=wq-3zsiBID8
Heating element assembly part link ==> http://www.repaircli...er=110.69422801
And how to replace it :
http://www.youtube.com/watch?v=_yL-WO_eRic
Testing the Thermal Cutout and Hi Limit:
http://www.youtube.com/watch?v=3nicyh6EUHc
Part link to the TCO and HL ==> http://www.repaircli...er=110.69422801
And how to replace 'em:
http://www.youtube.com/watch?v=VHYg_I90ONo
#4 jumptrout
jumptrout
  • 1,382 posts
  • Flavorite Brew:Coors Light
Posted 19 June 2012 - 06:15 AM
The centrifugal switch on the motor may be open if all these other parts check correctly.
#5 RegUS_PatOff
  • 33,588 posts
Posted 19 June 2012 - 06:18 AM
and / or full of Lint
#6 certified tech group 51
  • 2,694 posts
Posted 20 June 2012 - 09:42 AM
Access the motor, remove the plug, set your meter to continuity, attach the leads to the terminals listed as M1 and M2...... ( the ones with the large red wires)................use your finger and actuate the centrifugal switch........Continuity?????................................ If a lot of lint and fuzz, you can use some compressed air and blow the lint/fuzz out of the contacts to see if any thing changes........................
#7 kevinmac6591
kevinmac6591
    Ikkō-ikki
  • 20 posts
Posted 20 June 2012 - 06:09 PM
thats the ticket. changed out motor . problem fixed works great thanks for everybodys help
#8 RegUS_PatOff
  • 33,588 posts
Posted 20 June 2012 - 09:23 PM
http://www.repaircli...PartDetail/2584
