KitchenAid Oven Microwave Combo Built in KEMC308KBL04 Microwave Door Flops Down
7 replies to this topic
#1 Ritz
Ritz
    Kohai
  • Chief Appliantologist
  • 435 posts
Posted 18 June 2012 - 10:33 PM
I've been sent on what I would term a "rescue mission" The microwave oven door is supposed to open and stop where ever the user wants it to stop. Instead this one just flops/slams/falls open when you open it and take your hand off of the handle.
Both torsion springs have been replaced by a previous tech.
http://www.repaircli...er=KEMC308KBL04
Hoping someone can shed some light on this kind of microwave oven door repair.
Thanks in advance for any advice!
#2 RegUS_PatOff
  • 30,192 posts
Posted 18 June 2012 - 11:27 PM
there seems to be (3) different Torsion Springs
Left is lighter than Right
Stainless model uses heaviest right Spring
some instructions at APP ...
Part number: 4452396
search for part # 4452396
then scroll down to the 2nd question
click on answer
click on link
Pictures at post # 11 (which is on page 2)
must be logged in for pictures to appear
#3 Chat_in_FL
Chat_in_FL
    Senpai
  • PipPipPipPip
  • 894 posts
  • Flavorite Brew:Variety is the spice of life!
Posted 19 June 2012 - 04:51 AM
And just to mess with us techs, the heaviest spring is usually not mentioned on the parts list...
Mother Teresa
#4 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,463 posts
  • Flavorite Brew:Killians Red
Posted 19 June 2012 - 06:59 AM
And, in my experience...even with the heaviest springs, they will NOT hold this door in any postiton, only serves to reduce the weight of the door. Customer must still catch door before I slams down...
#5 Ritz
Ritz
    Kohai
  • 435 posts
Posted 19 June 2012 - 05:09 PM
Thank you for the replies. I have seen these oven micro combos before many times. I really cant recall of the door is supposed to "hang" in any position after you let go.
I have replaced the torsion springs before and it did not "hang" when let go....it did drop all the way open. Customer was satisfied so I called it good.
There are new torsion springs on the unit so I am going yield to any suggestions posted.
Many thanks!
#6 Patricio
Patricio
    Kohai
  • 437 posts
  • Flavorite Brew:Most anything wet excluding DR. Pepper
Posted 19 June 2012 - 06:13 PM
I replaced the torsion bars in one of those units a couple of months ago. Piece of cake putting the bars in, the heavy spring (blue)crosses from bottom right to upper left, & the lighter spring crosses from lower left to upper right. Door was heavy with broken heavy spring & plastic backing was POS, thin & flimsy, I had to replace it two. It took 3 deliveries & extra packing to get it in one piece from the warehouse. It did make a difference door opened & closed easily, but it was either opened full or closed full, no in between. Only difficulty was
trying to install the door back on the flimsy door backing..
Patricio...Tight Lines
IgonFishn & Tight Lines
#7 RegUS_PatOff
  • 30,192 posts
Posted 20 June 2012 - 01:13 AM
16 RH Torsion Spring 4451009
RH (For SS MDL) 4452396
17 LH Torsion Spring 4452395
#8 Patricio
Patricio
    Kohai
  • 437 posts
Posted 20 June 2012 - 11:52 AM
Not sure how to post a quote, but here goes: Hevy spring is #16 @ lighter spring is #17.
