Kenmore HE2 110.46462500 F28 code
6 replies to this topic
#1 kdorer
kdorer
  • 4 posts
Posted 20 June 2012 - 11:20 AM
Kenmore HE2, 110.46462500
F28 error code
Test mode: no drum spin, no water flow, nada. I can hear periodic clicking. (And YES ground switches are taped down for testing)
According to :
http://fixitnow.com/...t-sport-washer/
Motor ohm'ed correctly
MCU voltage good, continuity good
Replaced door lock switch
Replaced pressure switch
Tried new MCU, no change (still got F28)
Tried new CCU, test mode just ends with no lights - All lights go off and door unlocks - but no drum spin, no water flow, no nuthin'.
Put in old CCU and get F28 error code.
Any ideas?
I replaced drum about a year ago so with great instructions from the samurai, I was hoping to get a little more use out of this pos but I'm about ready to return parts and take a bat to it!
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 20 June 2012 - 11:56 AM
Has this Washer worked for you OK up till now at this location?
Did you check to see if there are other Error Codes stored ?
    Shōgun
  • Master Samurai Tech
  • 31,403 posts
Posted 20 June 2012 - 01:48 PM
Make sure all the panel are in place when you test run this beast or it'll keep throwing F28 and have you running in circles ==> http://fixitnow.com/...oor-panels-f28/
#4 kdorer
kdorer
  • 4 posts
Posted 20 June 2012 - 11:44 PM
Yes the washer has worked in this location for several years.
No, there are no other codes stored.
#5 kdorer
kdorer
  • 4 posts
Posted 20 June 2012 - 11:50 PM
The lower front panel is in place and as the link mentions I have taped the rear ground switch closed.
#6 Budget Appliance Repair
  • Senior Appliantology Fellow
  • 5,204 posts
Posted 21 June 2012 - 06:32 AM
Check the complete ground wire system, it goes from the bearing area behind the main basket pulley down thru front and back panel switches and then to the MCU.
William Burk (Willie)
Eureka, CA 95501
#7 kdorer
kdorer
  • 4 posts
Posted 27 June 2012 - 01:11 PM
Checked ground connections and continuity from hub to mcu, front switch, back switch, motor - all seems to be functioning properly.
