amana dishwasher model adb1400awb1
#1
Posted 20 June 2012 - 06:28 PM
#2
Posted 20 June 2012 - 09:38 PM
... checked with my little stick voltage detector on wires to valve(while machine was running and trying to fill)and it beeped and flashed.
that's why I don't like to use voltage sticks...
The Water Valve has L1 constant 120v through the Float Switch.
The Controller sends the Neutral to energize the Water Valve.
To check for 120v across the Water Valve connectors,
you may have to improvise, and carefully use some thin extension wires on your Meter Probes.
May be a bad Controller...
http://www.repaircli...tDetail/1938513
#3
Posted 21 June 2012 - 06:48 AM
If it is, there are two pads just behind the white plastic connector body on the top side of the coil that can be accessed with your meter probes with all connections attached.
You may have to disconnect the valve from the body of the dishwasher and let it hang down to see and access the test spots.
Eureka, CA 95501
