dishwasher repair
no spray grinding noise dirty dishes grinder
10 replies to this topic
#1 ljmom24
ljmom24
  • 16 posts
Posted 21 June 2012 - 08:31 PM
Hoping someone can help. A few weeks back I ran my dishwasher and it started making a horrendous loud buzzin/grinding noise. Needless to say, the dishses did not get clean. My husband and I took the whole thing apart and when we got to the food grinder, the screen was very clogged with stuff including a few old toothpicks. We cleaned it out, put it back together and ran it again and it ran fine. Yesterday, I loaded it up, turned it on and realized it was not making the usual splashing sounds and the dishes were not clean. As far as I can tell, the top arm was not spinning at all and I don't know if the bottom arm had much pressure. Took out all of the bottom parts again, the food grinder screen was full of stuff again although no toothpicks. We cleaned it out, put everything back together and now it is running fine. What is going on? Is the food grinder not working so that is causing some other problem? Any suggestions of parts I might need to replace? Thanks for any help anyone can offer!
#2 RegUS_PatOff
  • 30,266 posts
Posted 21 June 2012 - 09:32 PM
… remember, no matter what the salesman says,
it’s a dishwasher, not a garbage disposal.
:whistling:
  • 24,321 posts
Posted 21 June 2012 - 09:37 PM
Well, without a model number, all I can offer you is general help on dishwasher repair ==> http://www.repaircli...her-Repair-Help
#4 ljmom24
ljmom24
  • 16 posts
Posted 22 June 2012 - 06:57 AM
It is a Kenmore smartwash...idk the model number. It's probably 8-10 years old.
  • 24,321 posts
Posted 22 June 2012 - 07:23 AM
Model number help here ==> http://www.repaircli...My-Model-Number
#6 ljmom24
ljmom24
  • 16 posts
Posted 23 June 2012 - 10:57 AM
I think this is the model number: 17502200
Is it possible that the food grinder is not working and that is blocking the flow of water into the pump?
#7 RegUS_PatOff
  • 30,266 posts
Posted 23 June 2012 - 11:11 AM
... I think this is the model number: 17502200
would that maybe be 665.17502200 ?
is there enough water in the D/W ?
#8 ljmom24
ljmom24
  • 16 posts
Posted 23 June 2012 - 11:40 AM
For the model number all I see is a bar code and the numbers I gave you are below it. I don't see the 665, but that doesn't mean it's not there somewhere!
I think there's enough water. How would I know?
Also, it is running now and it is make a quiet buzzing sound, but otherwise appears to be working. I don't remember if that buzzing is always there or not!
#9 ljmom24
ljmom24
  • 16 posts
Posted 30 June 2012 - 08:14 PM
Sooooo....do you all think I should replace the food chopper?
  • 24,321 posts
Posted 30 June 2012 - 08:23 PM
Without seeing the problem (videos, photos, etc.) you could try the chopper and that may fix it ==> http://www.repaircli.../8268383/830886
If not, then you'll need to replace the motor-pump assembly ==> http://www.repaircli...0239405/1548519
#11 ljmom24
ljmom24
  • 16 posts
Posted 30 June 2012 - 08:42 PM
Ok thanks! I will try replacing the food chopper first, otherwise it will be a whole new dishwasher as I only paid $350 for this one!
