Gas oven stuck on self clean for 3 weeks
5 replies to this topic
#1 tahoebunny
tahoebunny
  • 1 posts
Posted 22 June 2012 - 09:12 AM
Hello, I was wondering if there is anyway a oven could stay on self clean mode for 19 days. This sounds crazy but, I clean houses and I went to clean a house that the people had just moved out of on the 1 of the month. I showed up on the 17th to clean it and notice how hot it was in the kitchen. I checked the oven and I was locked in self clean. Nobody had been at the house for the whole time so I can only assume that it has been on the whole 19 days. I wouldnt have believed this is possible, but I saw it with my own eyes. I've only seen ovens that let you self clean for only up 3 hours, they shut off after that. I'm scared to see the gas bill for this because it's propane and that stuff isn't cheap these days.
#2 RegUS_PatOff
  • 30,201 posts
Posted 22 June 2012 - 01:02 PM
“My Rules”:
Rule # 1) Don't ever use Self-Clean on any Oven.
Rule # 2) If you're thinking about using Self-Clean, see rule # 1.
Self-Clean uses nearly 1000F for 3 hours or more. Posted Image
That can wreak havoc on Electronic Controllers and Connections.
#3 jumptrout
jumptrout
  • 1,126 posts
  • Flavorite Brew:Coors Light
Posted 22 June 2012 - 03:06 PM
If it is still heating turn off the gas supply.
#4 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 691 posts
Posted 22 June 2012 - 10:00 PM
NOTE *** Oven should be clean by now. :woot:
#5 Scottthewolf
Scottthewolf
    Senpai
  • 1,911 posts
Posted 22 June 2012 - 11:45 PM
Somebody is lucky the house didn't catch on fire.
Usually, a thermal cutout switch would have turned the oven off when the heat reaches a certain temperature.
Scott Wolf
#6 RegUS_PatOff
  • 30,201 posts
Posted 23 June 2012 - 07:39 AM
... Usually, a thermal cutout switch would have turned the oven off when the heat reaches a certain temperature.
unless it was by-passed, along with Dryer safety thermals, all-too-often by the home-owner :burnin:
