Bosh Dishwasher
4 replies to this topic
#1 trevorstorey
trevorstorey
    Ikkō-ikki
  • 25 posts
  • Flavorite Brew:Homebrewed IPA
Posted 23 June 2012 - 09:07 PM
Hi Gurus,
I'm trying to figure out a Bosh Dishwasher Mod: SHE43M05UC/50 no fill problem.
When turned on the unit immediately begins circulating the existing soapy water from the bottom spray arm with low pressure. The fill valve is clean, clear, and getting voltage. I took the side panels off to view the fill/drain/float assembly and ran the unit, it is clear that there is no water entering the fill hose, float assemply or dishwasher cabinet nor through the rinse pump. The timer counts down and it only circulates the existing water. Also, the detergent dispenser will not open either.
It appear to be stuck in this circulation mode. Any suggestions?
Also, does anyone know of a good place to purchase service manuals? I tried servicemanuals.net for this Bosh dishwasher model but found no hits. I'm a new tech and am looking for a good service manual source (even if I have to pay a bit).
Thanks I appreciate the help!
    Shōgun
  • Master Samurai Tech
  • 30,057 posts
Posted 23 June 2012 - 09:12 PM
If the valve is not letting water in, even when it's getting voltage, then either the water supply is shut off or the valve is bad ==> http://www.repaircli...r=SHE43M05UC/50
#3 trevorstorey
trevorstorey
    Ikkō-ikki
  • 25 posts
Posted 23 June 2012 - 09:50 PM
I tested the water supply. Its definitely not shut off. Could it be anything other than the valve then?
#4 trevorstorey
trevorstorey
    Ikkō-ikki
  • 25 posts
Posted 23 June 2012 - 09:53 PM
Because I Ohmed out the valve and it was good.
    Shōgun
  • 30,057 posts
Posted 23 June 2012 - 09:59 PM
Ohms testing is merely preliminary and is not diagnostically conclusive. Something can test good on ohms but still be bad. You could try energizing the valve with a test cord. Have you measured the voltage at the valve?
