howiel967
Kenmore 790.78624405 oven doesn't ignite
8 posts in this topic
I can see the glow in the back but the oven does not ignite
All else works, including the broiler
Thanks! I kinda thought it was that.
Having a little issue getting the ignitor out
One of the two screws holding it to the bracket seems stripped, just goes around and doesn't back out
Tried using a screwdriver under the head while turning, to pry it a little but it hasn't worked
Any thoughts or tips?
that should've worked ..
Try placing the screwdriver under the Bracket
yep that worked - took forever and the little bolt threads are a mess
could try using the next size sheet metal screws
Stainless steel screws wouldn't hurt ..
Will do thanks for your help, all you guys are great and fast on responding!
One other ting, I have lost a couple of the little metal inserts for the knobs on the range. Do you know where I could find the metal inserts for the range knobs?
Take your scissors and cut a metal strip from a BEER can.
Place the strip around the stem and trim it to size.
Slide the knob over the metal strip.
It will hold.
