Using a Megger to Check Out a Refrigerator Compressor
megger megaohmeter compressor refrigerator
No replies to this topic
#1 Samurai Appliance Repair Man
  • 24,264 posts
Posted 25 June 2012 - 08:46 PM
When a compressor stops starting reliably, you can't replace a part like a start relay and move on; you have to investigate why the compressor stopped starting to determine if the bad start relay was a cause or an effect of another cause. For example, if the compressor fan is not running at rated speed, this will make the compressor run at a higher temperature and pressure and draw more current when it starts, thus drawing more start current and shortening the life of the start relay. See this instruction for more on that ==> http://appliantology...nser-fan-motor/
Another cause of a compressor not starting reliably is compromised insulation on the motor windings inside the compressor. This can be easily checked using an inexpensive instrument called a Megger, short for megaohmeter. This video explains...
Here are start relays and devices for various refrigerator compressors ==> http://www.repaircli...arch=Find Parts
And here's the hard start kit I installed on this refrigerator compressor to get it working reliably again ==> http://www.repaircli...237?RCAID=24038
Here's the updated Supco megger I use to check compressors ==> http://www.amazon.co...ASIN=B000LDHPAO
You can find whatever appliance part you need through the parts search box right here at Appliantology.org. No harm in buying and trying with our 365-day, no-hassle return policy, even on electrical parts that were installed!
The Appliance Guru provides prompt, convenient service in the following towns in New Hampshire: New London, Elkins, Wilmot, Springfield, Georges Mills, Sunapee, Mt. Sunapee, Newbury, Sutton, Bradford, Warner, Grantham, and the Eastman Community. Visit our website for more info and a discount coupon on your next service call: ==> http://applianceguru.com
Subscribe to our FREE, award-winning newsletter, Appliantology: The Oracle of Appliance Enlightenment ==> http://newsletter.appliantology.org and download your free report on appliance brand recommendations! Every issue is jam-packed with appliance repair tips and inside information direct from the Samurai's fingertips to your engorged and tingling eyeballs.
Also tagged with one or more of these keywords: megger, megaohmeter, compressor, refrigerator
