WR30X10012 Ice maker not working
Hot Point GE Ice maker
2 replies to this topic
#1 robrdavis
robrdavis
  • 6 posts
Posted 25 June 2012 - 11:17 PM
I have a HotPoint HSS25IFMDCC SxS with a WR30X10012 ice maker that has stopped producing ice. I've traced out the wiring in the ice maker as per the diagram printed on the cover, as well as checked that the water valve is working. It seems as though it's not calling for water, but I'm at a loss as to what to check next.
Freezer is at 9 degrees so it's cold enough.
I have the tech manual for the unit, but other than showing how to access and replace the ice maker, it has no other info on the ice maker.
Is there a manual available for the ice maker itself? Any other suggestions?
Thanks!
  • 24,289 posts
Posted 26 June 2012 - 03:59 AM
That's what we professional appliantologists call a " bad ice maker." Not uncommon with these. Just replace it, all good ==> http://www.repaircli...596?RCAID=24038
#3 robrdavis
robrdavis
  • 6 posts
Posted 26 June 2012 - 01:27 PM
That's the news that I was trying to avoid. Now to break it to my customer.
The question that I'm going to get is "But it worked when we took the fridge out. Why isn't it working now?" Of course, they took the fridge out when it quit cooling for the second time. They'd had a tech come out to service it, he replaced the main control board, it worked fine for a little while, then quit again. They called a different tech out who said that he needed to replace the main control board again. They weren't happy with that answer, so they bought a different fridge and put the HotPoint on the side of the house. I got a hold of it, found the problem to be the evap thermistor and replaced both it and the thermostat. It ran fine for about 2 weeks, then the evap fan went out. I just replaced it (and the new thermistor that I just put into it) and now it doesn't make ice.
I think I have found my arch nemesis in this fridge...
Thanks for the confirmation!
Also tagged with one or more of these keywords: Hot Point, GE, Ice maker
