Kenmore HE2 110.46462501 Cannot resolve F28 Error
3 replies to this topic
#1 intensityderen
intensityderen
  • 10 posts
Posted 27 June 2012 - 12:33 PM
I am completely stumped by this washer. When I start a cycle the washer locks the door and then just sits there until it times out and I get the F28 (Rinse,Spin,Clothes Clean lights) error. I replaced the MMU with no change and then the CCU with no change. I also checked the continuity of the safety switches in the front and rear to ensure they were working. Still does the same thing. Any ideas???
#2 newtech11
newtech11
    Ikkō-ikki
  • Chief Appliantologist
  • 27 posts
Posted 27 June 2012 - 01:45 PM
Try this
Reference Status
LEDs chart, page
6-4
SERIAL COMMUNICATION ERROR
The communication between the Central Control Unit (CCU) and
the Motor Control Unit (MCU) cannot be sent correctly.
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
– Check connections of the CCU board within the housing.
– Make sure all grounding switches are engaged.
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic Test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing
the MCU connectors.
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 27 June 2012 - 02:29 PM
has this Washer worked OK for you up till now at this location ?
    Shōgun
  • Master Samurai Tech
  • 30,015 posts
Posted 27 June 2012 - 03:13 PM
This page shows you how to test the MCU ==> http://fixitnow.com/...ntrol-unit-mcu/
MCU part link ==> http://www.repaircli...er=110.46462501
Comes with a 365-day return policy.
Make sure all the panels are in place or the open ground will throw an F28.
