LG washer fills & drains, that's it
LG washer
4 replies to this topic
#1 Patricio
Patricio
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 507 posts
  • Flavorite Brew:Most anything wet excluding DR. Pepper
Posted 27 June 2012 - 10:26 PM
Person who roofed our house calls today & says washer fills & drains but does not agitate or spin. Says error code is LE or DE can't remember. I sak if motor/machine is making noise. Reply is nada. I'm thinking door switch, research tells me hall switch.
Any comments?
King fish are biting off the jetties. Tight lines.
IgonFishn & Tight Lines
#2 RegUS_PatOff
  • 30,708 posts
Posted 27 June 2012 - 10:53 PM
model number ?
  • 24,721 posts
Posted 28 June 2012 - 07:10 AM
Diagnostic and troubleshooting tips for the LE error code in these machines ==> http://fixitnow.com/...ses-and-repair/
Tip: It's usually a bad hall sensor caused from using the wrong type of detergent or too much.
#4 Patricio
Patricio
    Senpai
  • PipPipPipPip
  • 507 posts
Posted 29 June 2012 - 12:13 PM
Don't have the model number, but called my friend about the washer. Told me after I told him to reach down & wiggle jiggle the switch, he slamed the door a couple of times (like kicking the tires) unit worked again. So for now everything is Ok.
I have researched the Hall sensor, but tell me exactly what it does. Is there a way to test them? Doesn't LE code in reality Mean the motor & electronics are not on the same page, I have to figger how to put pages in order.
  • 24,721 posts
Posted 29 June 2012 - 09:30 PM
Yes, you can test them. This page explains how ==> http://fixitnow.com/...loading-washer/
