PSS29NGMBWW GE Artica SxS Ref
megadan66
A friend has this ref. and tells me the freezer is running at 25 and ref is 45. and the condesor running through the wall inbetween ref and freezer is super hot. Could this be sensors ?
  • megadan66
... and the condesor running through the wall inbetween ref and freezer is super hot.
clean the Condenser Coils behind the Fridge... and check it's Fan operation
click on picture
Condenser-Fan-Motor-WR60X10209-00656730.
