The condenser is a heat exchanger where the refrigeration system gets rid of all the heat that's been removed from the compartments and the heat generated by the compressor itself. It's called a condenser because the refrigerant enters as a vapor but, as it cools, it condenses to a liquid. A dirty condenser will make ANY refrigerator warm up-- this is not unique to Sub-Zeros.
BTW, the condenser on the Sub-Zero 550 is up on top, behind the front grill. On most other refrigerators, the condenser is located at the very bottom of the refrigerator, either in back with the compressor or in front behind the plastic toe grill. Here are a couple tools that will help you clean the bottom condensers:
Condenser brush ==> http://www.repaircli...303318693/12859
Vacuum hose attachment for cleaning condensers ==> http://www.repaircli...171579A/1544893
The other common cause for this problem is a bad condenser fan motor. If the condenser fan motor in your refrigerator is burned out, you can buy the replacement motor here ==> http://www.repaircli.../4200740/753856
You can find whatever appliance part you need through the parts search box right here at The Appliantology Academy. No harm in buying and trying with our 365-day, no-hassle return policy, even on electrical parts that were installed!
Subscribe to our FREE, award-winning newsletter, Appliantology: The Oracle of Appliance Enlightenment ==> http://newsletter.appliantology.org and download your free report on appliance brand recommendations! Every issue is jam-packed with appliance repair tips and inside information direct from the Samurai's fingertips to your engorged and tingling eyeballs.
The Appliance Guru provides prompt, convenient service in the following towns in New Hampshire: New London, Elkins, Wilmot, Springfield, Georges Mills, Sunapee, Mt. Sunapee, Newbury, Sutton, Bradford, Warner, Grantham, and the Eastman Community. Visit our website for more info and a discount coupon on your next service call: ==> http://applianceguru.com
Fixing a Sub-Zero 550 that's Warming Up in Both Compartments
Started by Samurai Appliance Repair Man, Jul 02 2012 01:03 AM
Sub-Zero condenser refrigerator
No replies to this topic
#1
Posted 02 July 2012 - 01:03 AM
Also tagged with one or more of these keywords: Sub-Zero, condenser, refrigerator
