Whirlpool Duet GHw9100lw2 - repair help
duet front loader whirlpool
4 replies to this topic
#1 jimvick62
jimvick62
  • 2 posts
  • Flavorite Brew:stoli o
Posted 03 July 2012 - 07:19 PM
I have a Whirlpool Duet that I just replaced the tub due to a bearing issue. Now when you start the wash cycle, the tub begins to fill and 3-4 minutes later it stops filling and the error code FH comes up on the display.
I've run diagnostics and it's failing on the c:01 and c:03 codes; all the other six codes pass. I've checked the hot and cold inlet valve for continuity, which it does have, with the valve disconnected. I can't find how to test the flow meter (code c:01).
Any help or advise would be greatly appreciated, thanks in advance.
Jim
  • 24,346 posts
Posted 03 July 2012 - 07:35 PM
FH means it's not detecting water flow at the flowmeter. Make sure the hose attached to the flowmeter is still attached to both it and the CCU and is clear of gookus. If it is, then replace the flowmeter ==> http://www.repaircli...owmeter/1381535
#3 nickfixit
nickfixit
  • 1,965 posts
Posted 03 July 2012 - 10:03 PM
You may have a hole in the tube that runs from the water level switch to the air dome at the back of the tub.
#4 jimvick62
jimvick62
  • 2 posts
Posted 04 July 2012 - 07:43 AM
thanks for both tips, I'll check both and let you know. appreciate the help!
#5 Rooster
Rooster
  • Chief Appliantologist
  • 13 posts
  • Flavorite Brew:Schneider Hefeweizen
Posted 14 July 2012 - 05:13 PM
Flowmeter fixed mine!
Also tagged with one or more of these keywords: duet, front loader, whirlpool
