Frigidaire Gallery GLER642AS3
Electric dryer noisy
12 replies to this topic
#1 grizltyear
grizltyear
  • 8 posts
  • Flavorite Brew:Sam Adams Boston Lager
Posted 05 July 2012 - 02:48 PM
My dryer started making loud vibrating noises after a load was started. I did initial investigations on here, took the written advice I saw and replaced the drum glides and the bearing. I started the it up after parts replaced no noise, added some clothes and about 2 mins into the dry cycle the noise started back up. The idler pulley is fairly new and spun freely; am looking for other possible cause and trouble shooting I can do. Thank you in advance.
Jeff
  • 24,348 posts
Posted 05 July 2012 - 03:43 PM
With new glides and idler, that really only leaves the rear drum bearing by default ==> http://www.repaircli...mber=GLER642AS3
#3 grizltyear
grizltyear
  • 8 posts
Posted 05 July 2012 - 04:05 PM
I replaced that at the same time with glides.... today even. it is crossing my mind it could be motor but i didnt want to go that route yet.
#4 RegUS_PatOff
  • 30,281 posts
Posted 05 July 2012 - 04:09 PM
post YouTube video ?
#5 grizltyear
grizltyear
  • 8 posts
Posted 05 July 2012 - 04:14 PM
I could try... not that smart.... let me see what i can do
#6 grizltyear
grizltyear
  • 8 posts
Posted 05 July 2012 - 04:54 PM
My first you tube video.... :sillytongue:
  • 24,348 posts
Posted 05 July 2012 - 05:18 PM
Good video! That loud hum sounds like either blower or motor noise to me.
#8 grizltyear
grizltyear
  • 8 posts
Posted 05 July 2012 - 05:29 PM
thank you. I did look at the blower before i did the video and it is clear of obstructions, fins need a little cleaning (did it a couple of years ago) but nothing major. Well I was hoping it wasn't the motor but oh well. Thank you again .
#9 Nick@AegisAppliance
Nick@AegisAppliance
    Ikkō-ikki
  • Chief Appliantologist
  • 28 posts
  • Flavorite Brew:Blue Moon
Posted 05 July 2012 - 06:59 PM
Did you look really hard at the blower wheel? Sometimes there is a hairline fracture between fins that causes it to spin off balance once it runs for a short while. I've experienced that issue on a gallery just like yours, and also an older maytag. It is difficult to spot, so u may want to try pushing or pulling on the fins as you go around the wheel to pinpoint it. Good luck!
#10 grizltyear
grizltyear
  • 8 posts
Posted 06 July 2012 - 02:41 AM
I will look harder at that, thanks for the suggestion. however after posting and making video it is now a constant noise. but again I will look thank you
#11 grizltyear
grizltyear
  • 8 posts
Posted 06 July 2012 - 03:35 PM
I looked harder at the blower pushed, tweaked, pulled found nothing. However I decided to remove the belt from the motor and start the dryer on air fluff/no heat. I ran it for about 5 mins no loud noises. I then put belt back on the motor and ran it again in the air fluff/no heat setting for 5 to 10 mins; again no noises. I turned the selector to the low heat setting and the noise started,........ I then switched it back to no heat and the noise continues. anyone have any thoughts, I am now assuming (bad habit) that the blower gets warm and that when my trouble starts.
#12 RegUS_PatOff
  • 30,281 posts
Posted 06 July 2012 - 03:37 PM
#13 grizltyear
grizltyear
  • 8 posts
Posted 08 July 2012 - 09:30 PM
sorry it took so long to post... busy doing outside work since it got real nice out in the Pacific Northwest :rocker:
Also tagged with one or more of these keywords: Electric, dryer, noisy
