Condemn Refer?
8 replies to this topic
#1 Patricio
Patricio
    Kohai
  • Chief Appliantologist
  • 448 posts
  • Flavorite Brew:Most anything wet excluding DR. Pepper
Posted 06 July 2012 - 08:57 PM
Frigidaire SxS GLHSEESB4 compressor running, Head temp very hot. Codensor fan running, condensor coils clean & hot. Freezer dipping wet no ice but cool 32 degree with infra red beam, refer 54 degrees, evaporator fan running blowing cool air. Condemn sealed unit right call?
IgonFishn & Tight Lines
#2 RegUS_PatOff
  • 30,273 posts
Posted 06 July 2012 - 09:50 PM
any Evaporator frost ?
picture ?
#3 Patricio
Patricio
    Kohai
  • 448 posts
Posted 06 July 2012 - 10:29 PM
Water dripping all over back wall, customer had to go get ice chests to put freezer stuff in so I did not have time to hang around,will go back in moring. Not far from my house.
And it has been doing this since wednesday
#4 Patricio
Patricio
    Kohai
  • 448 posts
Posted 06 July 2012 - 10:32 PM
Also unit at plug pulling almost 2 amps, sheet says compressor should be be 1.2 - 1.5 amps.
#5 RegUS_PatOff
  • 30,273 posts
Posted 06 July 2012 - 10:43 PM
Was this Fridge moved, or cleaned recently ?
Wall Plug = Compressor + (2) Fans
#6 Patricio
Patricio
    Kohai
  • 448 posts
Posted 07 July 2012 - 09:04 AM
Will be going by customer's in an hour. What they told me was that they are remoldeling, moved Refer into hot garage where west sun hits refer when garage door open. It has been in garage runnuing for 2 months. They went fishing on 4th. Came back to put fish in freezer & it was defrosting in a wet puddle. They turned unit off For a day Then turned back on. When I showed up on 6th back refer wall was dripping & temps were what I stated. They also turned both unit settings to highest (9) digital readout.
Condensor fan pulls either 0.03 or 0.07 amps depending on the RPM. I don't have specs for evap motor.
I put settings at 5, told them to leave unit closed and am going back in a little bit to check on frosting pattern if any. Any thing else I might check for?
#7 RegUS_PatOff
  • 30,273 posts
Posted 07 July 2012 - 10:01 AM
... remoldeling,... moved Refer into hot garage
moved while upright ?
OR on it's side / back ? (then need to let Fridge "rest" for 24 hrs upright)
And / OR may also have bumped / damaged the Compressor / Condenser / Lines
If everything's OK, it may need to run up to 24hrs for temperatures to recover.
#8 Patricio
Patricio
    Kohai
  • 448 posts
Posted 07 July 2012 - 10:24 AM
Yes this is what I informed the customer, I needed to let it sit undisturbed overnight & I am going there now. I will post late tonight or tomorrow evening when I get a chance to get on the computer. Thank you Patricio
#9 Patricio
Patricio
    Kohai
  • 448 posts
Posted 07 July 2012 - 12:47 PM
Temps after a day, Freez=03F Fridg=34F.
Detective work=
1. moved frig into garage 2 months ago upright
2. got bait out of freez Wed. morning
3. came back with fish wed evening, melting mess, unplugged fridg off for a few hours
4. turned fridg back on.
5. I observed Friday afternoon temps & a wet mess in compartments & under unit. compartments were close to 100% full of food & defrosted.
6. Temps today good popcicles frozen hard in freezer, nothing else in it.
7. did dollar test on seals - snug, Used temp gun to look for air leak - 84/85 degrees all way round = good seal
8. further questioning they revealed unit was unpluged several times while doing remodel work
Diagnoses is systemr is just fine. I think haste in getting bait out of freezer something in freezer kept door ajar. Unpluging unit several times did not help either.
Prescription keep doors closed when not in it, find dedicated circuit, not the extension cord they are using, Go fishing again (they gots a big boat). Call me if they need my service again.
Patricio got to go.
