ASKO washer W6021 / WM33A not spinning
2 replies to this topic
#1 Nutterman
Nutterman
    Ikkō-ikki
  • 29 posts
  • Flavorite Brew:New Castle
Posted 09 July 2012 - 10:44 AM
I've got this washer that won't spin. My first trip I found visible burns on control board. Ordered it and replaced it. Its a 1200 RPM model with 5 rinses. I know that the correct cuts are made on the J1 thru J5 terminals. The door latch tests good and so does the pressure sensor. So I put a new motor in it. The motor tested fine but it just didn't sound right when I spun it by hand. I still don't have spin. It will turn the drum a few times CW then CCW while draining. (pump tests good also) then it pops the door open and beeps like its finished. I'm out of ideas. Mayday! Mayday!
#2 Nutterman
Nutterman
    Ikkō-ikki
  • 29 posts
Posted 10 July 2012 - 03:35 AM
Thanks for your help!
#3 RegUS_PatOff
  • 30,687 posts
Posted 10 July 2012 - 07:02 AM
http://appliantology...service-manual/
