waterflea
microwave problem
2 posts in this topic
Hail exulted one!
Once again I turn to you for help. This time my microwave is giving me fits. Sharpe Carosel, can't find the model #. Built in with trim kit. Light come on, timer starts, no fan, no carosel. Sometimes I can get it to flicker by playing with the door opening button, which makes me think it might be a switch. The one fuse I can see, seems to be fine. Any thoughts.
Thanks
Bruce
This is usually one of the door interlock switches-- those are the switches in the door latch mechanism in the cabinet that are actuated by the hooks on the door. One of those switches may be stuck open. If they check out ok, then you need to check the power supply to the control board, should get 120vac at the power wires on the board.
