Maytag Fridge issues
#1
Posted 10 July 2012 - 03:00 PM
A few issues with our Maytag fridge:
1) Only a trickle of water comes from the filtered water dispenser
2) The water dispenser does not turn off even if I take the glass away
3) Ice cubes are not dispensed although I hear the noise
4) Ice forms at the bottom of the freezer
#2
Posted 10 July 2012 - 03:21 PM
Item 2 replace the fountain switch ==> http://www.repaircli...mber=MSD2758DRB
Items 3 and 4: check back later.
#3
Posted 10 July 2012 - 03:27 PM
Is this Fridge connected to an external Water Filter ?
#4
Posted 11 July 2012 - 09:00 AM
This problem started happening a couple of weeks after I replaced the water filter. I took off the water filter, put a large cup where the filter should be, closed the door and pressed the water dispenser. The cup filled up very quickly. I don't know what that means though.
>>>>Does this Fridge use a "self piercing" saddle clamp Valve to connect to the House Water Supply ?
Apologize... I have no idea what this means.
water filter is inside the fridge.
#5
Posted 12 July 2012 - 07:44 AM
The Saddle tap valve skinny:
Ice at the bottom of the freezer means a clogged condensate drain at the bottom of the evaporator coil in the freezer.
#6
Posted 12 July 2012 - 01:09 PM
#7
Posted 12 July 2012 - 01:13 PM
yes, may be partially frozen ..... Does that mean there is some issue between the filter and the dispenser?
OR the Line is kinked somewhere (bottom of Door / Hinge) ?
#8
Posted 12 July 2012 - 05:28 PM
#9
Posted 12 July 2012 - 06:46 PM
City water ?
Well water ?
Any recent plumbing repairs ?
#10
Posted 12 July 2012 - 10:41 PM
something in your water ?
City water ?
Well water ?
City water. No recent plumbing repairs.
#11
Posted 14 July 2012 - 09:28 PM
Could you please let ne know how I can resolve the other two issues below:
1) The water dispenser does not turn off even if I take the glass away
2) Ice cubes are not dispensed although I hear the humming noise
#12
Posted 14 July 2012 - 10:03 PM
Answered a long time ago, at the beginning of this topic:
#13
Posted 17 July 2012 - 05:13 AM
Pull the ice bucket off. Make sure ice isn't clumped in bottom of it and frozen together. With freezer door open, hold in light switch and activate ice lever at the dispenser front. You should see the ice auger motor turning. If it just sits and hums you may have a frozen auger motor. If it turns, the problem is in the ice bucket or the dispenser door isn't opening.
