Kenmore Elite SxS 106.4419300 how to check the defrost system
2 replies to this topic
#1 Ritz
Ritz
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 554 posts
Posted 11 July 2012 - 06:14 AM
This SxS had the evaporator completely frosted over. It's the SxS type with the infrared indoor ice system. The defrost heater tested closed so that is ok
Can I get some tips on how to check the defrost thermostat:
http://www.repaircli...8206671/1027658
Or the main board:
http://www.repaircli...8206668/1027657
I'm assuming it's got to be one of those two. Can someone tell me how put the unit into defrost mode or diagnostic mode so I know which parts has failed?
Many thanks in advance !
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 11 July 2012 - 08:03 AM
106.4419300
106.44109300 ?
hhmmm ..
no tech sheet,
but from (maybe similar) GC1SHAXMQ00 service manual
Defrost can be initiated by disconnecting and reconnecting power.
Main control board will attempt to initiate defrost upon restart:
• If bimetal is closed, defrost cycle will start.
Relay on main control board will click one time.
• If bimetal or defrost circuit is open, defrost cycle will not start, and the cooling cycle will begin.
Relay on main control board will click twice
(once to initiate defrost and the second time to switch back to cooling).
there's also a Fuse inside the Defrost Thermostat :woot:
http://www.repaircli...tDetail/1027658
#3 Ritz
Ritz
    Senpai
  • PipPipPipPip
  • 554 posts
Posted 13 July 2012 - 09:59 PM
Thank you for the valuable information! Interesting that no one has this defrost thermostat in stock. (wondering if this is a common failure part as I'm not familiar with this unit)
I am going to pull it apart and see if I can test the fuse... Thank you agin for the instructions on starting the defrost cycle and other helpful info!
