Kenmore 110.24862300 - spin cycle
5 replies to this topic
#1 jmm
jmm
    Ikkō-ikki
  • 42 posts
Posted 14 July 2012 - 10:19 AM
I wrote a couple weeks ago about this washer not spinning - diagnosed a clutch and whi;le I was in there - reolace the drive block. I replaced both the clutch and drive block today. First try on the spin cycle and the tub was bucking like crazy. I tore it down again and realized I did not have the drive block on correctly - thought it was an easy fix. I put it on right and tightened it down with the spanner wrench just like in the video but no luck - it still bucks like crazy when it gets up to speed. I even put the old drive block back on, checked the mounting bolts for the drive assembly to see that they were tight, looked at all the suspension springs, etc to see that I had not inadvertently done something to them - no obvious problem. Any idea what I messed up? Laundry was done yesterday so I have a couple days to get out of hot water....
#2 Nick@AegisAppliance
Nick@AegisAppliance
    Ikkō-ikki
  • Chief Appliantologist
  • 28 posts
  • Flavorite Brew:Blue Moon
Posted 14 July 2012 - 11:09 AM
When you were replacing the drive block- did you have to pull up hard on the basket to get it out? Sometimes when the basket is pulled on too hard it, it can mis-align the suspension pads on the base (Ive made this mistake before). On top of each "leg" from the base (there are 3) you will find either a brown or white pad make sure they are all there and not broken. above that, you will see a plate that the whole tube assembly rests on, and on the plate you will see shiny wear marks. make sure those marks line up the the white or brown pads below them. If they are off, then you will find that your machine will shake uncontrollably under any size load, even empty.
#3 RegUS_PatOff
  • 30,190 posts
Posted 14 July 2012 - 11:12 AM
Maybe bad / loose connection at Washer Motor
May be a bad Speed (Cycle) Switch
(try it set for different speeds)
Post YouTube video ?
http://www.repaircli...tDetail/1454262
#4 jmm
jmm
    Ikkō-ikki
  • 42 posts
Posted 14 July 2012 - 01:09 PM
I did have to pull pretty hard to get the tub out - I will check the suspension alignment tonight - busy working outside in the 90 degree, high humidity environment for the rest of today. Makes me appreciate the office during the week....Thanks for the help!
#5 jmm
jmm
    Ikkō-ikki
  • 42 posts
Posted 14 July 2012 - 07:30 PM
Just looked and the pads were definitely out of line. Is there a repair video or instructions on how to line those buggers up and/or replace them? One of them is definitely broken.
#6 Nick@AegisAppliance
Nick@AegisAppliance
    Ikkō-ikki
  • 28 posts
Posted 14 July 2012 - 07:52 PM
Parts and video here
http://www.repaircli.../><br /><br />I was looking at the video, and when I replaced those pads I just used one arm to lift the tub assembly up and replaced each pad one at a time with my other hand.Just be careful not to let it slip or you could smash a finger or two.. or your whole hand! You could also have someone help tilt the tub assembly. But since you have already disassembled this unit from top to bottom, doing it as the video shows wont hurt you any.
